D16y8 swapped. No f@#%&ing power now under load. Fuel issue, injecters? Help!!!
joehonda72
After completeing d16y8 into my 93 civic i first had issues with idleing and stalling. Ok, as of this morning i fixed all that. No the car has no power under gear load. Sounds mean as f**k. Equipted with header, skunk2 intake, skunk2 adjustable cam gear and cam, and a p28 chipped ecu mapped with chrome. But as soon as you put her in gear to mash out, she justg bogs out like some one cut off fuel supplie. Injecters, filter????? The only other change i made was some older injecters.
2slo4u
wait4me
How are your spark plugs? All the wires connected correctly?
Any CEL codes? My car had an issue like this twice. One time it was an o2 sensor issue, the second time it was a clogged injector and an issue with the ELD getting a bad signal.. or something like that.
joehonda72
Plugs are probably due for replacement, but worked fine in the other moter. Wires are installed correctly,.
joehonda72
you think it could be injecter or injecters to. these ones i have had laying around for a bit. i should modifie the injecter conncters and put the other ones back on huh?
2slo4u
wait4me
what were your old ones and what are the new ones? is your ecu chipped for the new ones (assuming they are a higher cc)
