D16z6 build
95civiclopez
ok so this is my first build and in kinda new to a turbo build at is so if u could help me out with it. so far this is what i got an older t3 t4 turbonetics turbo for the bottomend im sleeving the block but not sure if i should go with a bigger bore buting vitara pistons with eagle rod balancing the crank for the head i want to get everything aftermarket like valve valve springs retainers seals and cam but not sure what brand to run im thinging a stage 2 cam and titaniam retainer bigger fuel rail but like i said im new any info would be alot of help
Boosted2Hell
i wouldnt bore it out, for that small of a motor you want the walls as thick as possible so your able to run your turbo and boost safely. make sure you get it sleeved and a nice set offorged pistons and rods. you have the right idea. you can also maybe go with a bigger crank? but i would keep the stock bore size.
got traction
i rock the sohc
dont listen to anything in the above post.
OP- what is your horse power goal? Once you know this, then I can steer you in the right direction.
emerican
Without knowing your goal for it its pretty hard to help you out man. Listen to ^ got traction they know there s**t.
