i would say you are pushing max at 7...8 or 9 psi would definately do damage after time. You would not significantly reduce the life of you engine if you ran 5 or 6 psi. Once you get good rods, low compression pistons, springs, retainers, cams, and have your crank micropolished balanced and chammferred, bearings, etc... and have a good computer setup with 400+cc injectors (maybe fuel pump too) youd be good for like 12-17 psi depending on setup anything else would detonate unless youre willing to run race gas or do other extreme modifications like oil squirters and coolers.
