Dash light fuse keeps blowing
Pry the dimmer switch out of the dash, unplug the connector, and use a jumper wire to short the red wire to the black wire in the connector. If the dash lights now turn on full bright without blowing the fuse, then replace the dimmer switch.
If you unplug the dimmer switch but don't install the jumper wire, does the fuse still blow?
joedirt8872
I was told the previous owner used the cigarette lighter and noticed it started blowing fuses. Doesnt make any sense to me.....but i dunno.
Answer to question in post #4? Did you install an aftermarket stereo?
The cigarette lighter is protected by a different fuse.
moebiius
RONJ, you're like MR. CHAU, "I'm all over the place!" HAHA good looking out tho.....I've appreciated all your diligence and helpfulness....Thank you bro
