Deciding Between a Few Different Precision's
Strange World
B18C1 EG
I WILL RESPOND WITH MY ENGINE SETUP AND LINKS TO THE TURBOS.
Hello, I'm making some decent progress piecing together the parts for my turbo build. I'm hoping to make 500+ WHP with a powerband topping off at 9000 RPM (the lower the better), and keep a good spool time for the turbo. I'm expecting to have to boost to at least 20+lb, but if possible I'd like to cap off at 25lb.
After first cycling through reviews on different manufacturers, and comparing prices and models, I've decided to get a Precision turbo, and have (somewhat) narrowed it down between a few different models. I'm going to be getting a T03/04 journal bearing turbo, with a .63 A/R. THESE ARE THE MODELS I AM CURRENTLY CONSIDERING: 5831 MFS, 3431E, 6076E.
Any help is greatly appreciated. I don't care about preserving A/C or powersteering.
Strange World
B18C1 EG
ENGINE:
(ENGINE WILL BE EITHER THE B20 DESCRIBED BELOW, OR A B18C1 WITH THE SAME COMPONENTS)
B20 Block
B16 Head (Valve Job, Ported & Polished)
Darton MID Sleeves 84-85mm
CP Pistons 9.0:1 84-85mm
Eagle Rods
Skunk2 70mm Throttle Body
Skunk2 Stage2 Tuner Cams (305-05-0145)
Skunk2 Tuner Valve Springs (311-05-0350)
Skunk2 Pro Series Intake Manifold (Port/Polish)
Skunk2 Dual Core Aluminum Radiator
AEM V2 Cold Air Intake
ARP Head Studs
ARP Main Studs
AEM Fuel Rail
RC Injectors (800cc?)
Walbro Fuel Pump (LPH?)
Eagle Crankshaft (lift?)
TURBO:
Precision 3431E Turbo (???)
Spearco Intercooler [3.5x7.9x24] (5-383)
Synapse V-Band Ram Horn Header (syn-syn-man-04)
Synapse 3” Downpipe
BOV (Tial)
Wastegate
__________________________
As you can see, there are still several things I need to consider, however I'd like to get the turbo figured out now as it's one of the core components. Once I have that sorted out, negotiating the rest should be easier.
