2broke2bimmer
My girlfriend has a 1992 Honda Civic hatchback with 311,xxx on the clock. I believe it is a DX but I am not certain (I have no familiarity with Hondas). It is the automatic with manual locks, windows and mirrors. I've decided to tackle some of the issues her car has as they are likely more affordable to fix than my bimmer. Her instrument cluster does not illuminate checked fuse 15 and 10a and they looked good. One or two lights on the climate control panel illuminate but that's it. I have not checked the dimmer switch so I'm not certain that's not the culprit. When in reverse there is a shake at idle, is this due to bad engine mounts as I have read or is something else likely the culprit? The car is getting about 25mpg hwy which seems a bit low for a car with a 2300lb CW and a small engine. Only one of her speakers works I suspect that this is so to a shoddy wiring job installing two aftermarket speakers in place of the rear stock ones. I notice it has a D4 and a D3. D3 seems to provide a more eager throttle response and shift map but doesn't settle into overdrive. D4 seems more ecominded. I've only driven it once as I do not fit into it well as I'm 6'6". Just trying to get my bearing on this one thanks for any assistance you can provide.
Additional, what kind of year compatibility do these have, will parts from any 5th gen of similar trim fit this? When I had a firebird almost everything from any third generation fbody would swap on. Except the block which I discovered was a Canadian swap...
