did i just make this worse?
jmr828
well i had aftermarket reverse glow gauges that came with my car, and ever since i bought it they would flicker. they kept randomly going out and then back on, as if a ground was bad, and it did this for about two months to me, and im not sure how long to the previous owner, but he warned me about it and said he didnt know what it was. I tried all sorts of things, all sorts of different grounds, and a different power source, and it just wont stop flickering. as of two days ago it stopped working all together, so i said the hell with it, i checked it to make sure it has power, and it does, so i assumed that it was the "box" to the cluster. it's where the power and ground go into, and then there's a dimmer and wires to change it from green to blue. i said the hell with it and cut the wires, and tried wiring it directly, without that "box" and still no luck. did i just make a huge mistake by cutting that s**t off or is it just a garbage cluster or what?
I repeat, I ALREADY KNOW IT HAS A GOOD GROUND AND POWER SOURCE, so that isn't my problem.:evil:
highneo
Pi Lambda Phi
swap in a stock cluster. are these overlays on a stock cluster? most indigo gauges are just faces that go over the stock ones.
wfw12
pull off the indiglo all together, dont waste your time trying to fix something that looks like s**t
Genuine Rolla
Its PETEY PETE, y0!
its probably the connection that goes into the gauge faces.
jmr828
youre on crack if you think they look like s**t. but they deff arent worth the hastle. yeah stupid me, i just realized all it does is cover my stock gauges, so out with the indiglo b/s. thanks guys.
JDM-JNKY
In JDM We Trust
Take out the indiglo guages are you crazy keep your stock guages mad JdM yo!! Lmao typical clubcivic
Genuine Rolla
Its PETEY PETE, y0!
ROFL..
I had those kinds of gauges back in the day, they were alright but didn't match with anything else in my interior.
Check the connections once again and let us know if that helps.
