difference between PK2 (86-87 teg) and PG7 (88-89 teg)?
apekd
-----Distracted you, huh?
is there any difference? or can i throw that onto the OBD0 mpfi swapped D15B1?
hondadna
Rep the 330!
# 1986-1987
* Compression : 9.3:1
* Power : 113 hp (84 kW) @ 6250 rpm
* Torque : 99 ft·lbf (134 N·m) @ 5500 rpm
* Piston Code: PG6
Vacuum advanced Dizzy.
# 1988-1989
* Compression : 9.5: 1
* Power : 118 hp (88 kW) @ 6250 rpm
* Torque: 101 ft·lbf (137 N·m) @ 5500 rpm
* Piston Code: P29 (Equivalent to PM7)
Electronic controlled Dizzy.
Steven.
Formally Green 91
cant use the 86-87 since it has vac advace dissy,
