fuse is still good7.5A fuse 30 under the dash.
how do you check if the dimmer switch/adjustment still good?Mine also did this and my dimmer switch had went bad... Got a new one and they haven't gone out any more
How did you test it?fuse is still good
i mean its not blown,the wire inside is still intactHow did you test it?
i dont have a test light,i connect the red and black wire,and connect them into which connector??You can't always see that a fuse is blown. Use a test light to check the fuse as described at the Test Fuses link in my signature.
If the fuse is fine, pry the dimmer switch out of the dash and short the red wire to the black wire with a jumper wire in the free connector. Do the lights now work?
thanks bro,your always a big help.will try this out and see the results.will let you know..
