Dim Headlight Problem
JDvorsky96Si
Hey all,
So I looked all over the forums but couldn't find my exact issue, so maybe you can help.
My Drivers Side running lights, Low Beam and High Beam are all really dim. (Turn Signal works fine)
So far I've checked:
-Headlight Bulb itself
-Ground Wire is Tight
-Fuses are fine
Any other ideas of what it might be?
Thanks in advance
-Jdvorsky
Kenneth
Have you checked the alternator output?
RichardCrainium
check the pigtail for the headlight my pas. side was doing the same thing and I found the pigtail had melted a little I got one from oriellys. They had to order it but that's the only place I could find a new one. Or you could hit up a junk yard and just cut one out. Hope that helps
