yogibear27804
Replaced D15 head with the D16Y8 head and was wondering can you use the D15 distributor with the D16 head? As of right now, I installed a D16Y8 distributor and the connection isn't the same.
This guy learns fastI'm pretty new to this site and to Hondas but I've rebuilt a installed a clutch and replaced connecting rod bearings. I believe its because of this site and the ability to take direction. If you want help you need to include your vehicle info and all the details you can. Prior to this you should probably research first. I would start with
"can you use the D15 distributor with the D16 head? Im pretty sure you can in your case I'd like to hear what a more experienced person has to say. I'm thinking as long as it lines up with TDC and bolt pattern is the same I think so. Don't take my word but good luck.
^If you want help you need to include your vehicle info and all the details you can.
