DIY Clutch ????
89rexxin
Hey I need picture insturcions on how to change a clutch in a 96 civic HX.....thanks
Handlebars
None Taken.
dont need a helper, i did all my s**t by myself. but it is easier with an extra set ofo hands
smitty82pu
"hail hail to old Purdue"
true dat.. second time around i had some help and it went way faster and i even swapped trannys (went with an ex and boy what a difference).. and i know you are wondering, second time??.. well my '96 dx hatchie has 173k on her.. =) just disconnect everything, take out the axles (have to take apart lower arm to get out), disconnect linkage rods, support with a jack then take off the mounts and bolts.. then after the tranny is out of the way you can take off the pressure plate and your disk will fall right out.. make sure you use the alignment tool when you put the new clutch components in ;) and replace the throw out bearing! i know its a scrappy list but it should get you started thinking..
