DIY install zex comp cams 59300 cam springs and retainers
Dirtydserieswot
ok here it goes
starting to disassemble
be sure to clean valves and keep up with wich port they came from.
roll them on a flatt surface to see if they are straight
the sexy kit
one side done
gay ass spring compressor... just compress it and pull out the keepers .. they pretty much fall out themselves
Canon went for it everytime i put him on the floor
teaching him about a honda head
zex cam ready to go in....
lube up where the cam is going to seat with some assembly lube
simply place the cam in and make sure it is moving freely and that the cam seal is properly seated
next put on the rocker assembly and rtv where the ends are to make sure it seals
make sure all the arms are moving freely and are'nt caught on something
put the lost motion assembly on the rockers and put the bolts in place and hand tighten.. make sure ur lma's move freely oil them up...
tq the 12mm bolts to 14 ft lbs
and tq the 10mm bolts to 8.5 ft lbs
do them in the same order as head bolts
now adjust valve lash for zex cam its .007intake and .009exhaust
if you dont know how to do this search on hondatech.com
now your done
Trey99EK
Nice, how much did it set you back?
Dirtydserieswot
i get my parts at cost so about 450 total
for you it would set u back about 600 not a bad thing when u gain power up to 8500 and u can rev it there reliably
