do i take the spring out????
CacheHX
if i have a electronic boost controller. am i supposed to take out the preset psi spring or what
Steven.
Formally Green 91
spring out of the waste gate, no.
ryanM
no, the wastegate stops your turbo from making too much boost, your boost controller stops the engine from receiving too much boost, you need both.
91SiVTEC
yes .. Knowledge is Power
umm lil off topic... LongGrain How old are you?! i know its not 76....
Steven.
Formally Green 91
CacheHX said:
so does it matter what spring i have in the wastegate
get the lowest one( like .3bar, yellow i belive) so you can adjust to really low PSI if you have a problem adn need to go with out boost.
ryan89crx
Spoolin single cam!
decide on a spring based on what max psi you want to run...
reason i say this is because you should boost more than double your WG spring.
