you will need a wide-band PRIMARY O2 sensor and you will need to add an additional wire to connect the wide-band sensor. you will also have to add wiring for the EGR solenoid/valve that is on the Y5 engine.
Pretty damn essential if you ask me.Is the O2 sensor only to check the oxygen or does it have a essential job in the motor?
