Dreaming??
Tactics
yes officer, i understand
HA!.... Not anymore.... Greddy kit is on the way! FMIC included. i wanted to go custom..... but i have smog and s**t to worry about. =)
SeanMc300
professional a*****e
good for you, good luck with it. did you get the bov, guages, turbo timer???
Tactics
the timer and BOV will have to go on the next check!! Im sure it'll be a while before i can put it on. I know i still need some other crap too.... Sean, i cant afford hondata for a bit, if i deciede to turn up the boost, will the AFC (and injectors) method of controlling fuel "get me by" ??
99civic-boosted
Luke 10:27
I know that most ppl on here are not fans of the E-manage system that comes with the Greddy. However I have had much luck with them. If you decide to use it, take your time and read the instructions carefully and make sure to follow them. If you do, you should be good to go.
tonyM
caca poopoo
damn ,im GREEN with envy.
one day,,,,,,,,one day,,,,,,,,,,,,
(i have to keep telling myself that!!!)
banzai
Exit Speed Garage
congrats...I dont think you should turn it up past 7 until you get a good tune and all the other goodies.
And where did you get the kit at, and for what price - did the fmic come with the kit? and is it the big fmic or small? When I ordered mine I had to order the fmic seperate...thanks
Tactics
well, they were ordered seperatly but they call it a "package" it was 2400, no BOV, and i got the small IC.... (<---DAMN!!!) is that good or bad? (price)
banzai
Exit Speed Garage
thats a good price...for both. Hey what site was it?
SeanMc300
thats a decent price, and good thing you got the smaller one, you arent pusing enough cfms to actually utilize the larger intercooler. plus, youll get to keep your bumper support. yeah ifyou upgrade to some 440's or 450's, the afc will be fine, that is if you fine with it. if you want to upgrade and push the boost to around 10psi, youll NEED a gm 3 bar map sensor. also, the hack will cost you approx 350 just for the unit, id save up the extra 400 bucks and wait for hondata and tuning.
anekin007
Unregistered User
the greddy kit may say smog legal and crap..it is not 100% it will pass smog. just pass smog for visual..
Tactics
i already have the VAFC, so that parts taken care of.... and here in Boregon, they only test they do is plug in to the OBD port.... no visual unless your car is pre 90 or something like that. I hope ill be happy with this kit!
banzai
Exit Speed Garage
the more air you can get to the intercooler the better, the bigger the intercooler the better. Why do you say the smaller one is better?
99civic-boosted
Luke 10:27
I would have to agree
SeanMc300
Youre part right. the larger is better, only if youre pushing more air through it. Think of it this way too, the dsms only had small intercoolers...the 300zx o nly had a small intercooler....the skyline only has a small intercooer, yet they work perfectly fine. its realy only when you turn up to higher boost is when you need a bigger intercooler. the 5.5 psi the kit makes, makes the larger intercooler un-necessary. plus, you want to cut off your bumper???? get the smaller one, its capable of almost as much hp as the bigger one, atleast the most that kit will make, and you wont need to cut anything. bigger isnt always better.
Tactics
thanks guys...... now, who knows about this uberdata i read about? it sounds like something that i can implement since i have access to a rom burner. If anyone can offer any insight, i would appriciate it...... it sounds like a much better solution that the "hack" i was thinking of running...
SeanMc300
it acts, runs, and tunes JUST like hondata. its a free version of it. youll need to have it tuned by someone who knows how to use it...or any hondata person who is willing to tuen uberdata shouldnt have much trouble.
$lick Rick
TEOTWAWKI
you're in medford right? i'm comming down in a few weeks. we'll have to hook up so i can check that s**t out!
Ravage70
uberdata is obd1 only therefore u need an ecu from 92-95 and an ecu conversion harness
(obd2-> obd1)
check out homemadeturbo.com on what u need to chip ecus and s**t
Tactics
damn... ive been doing a lot of reading on the Uberdata..... it sounds like most of the bugs are worked out. I have access to a chip burner, so i thought that would be cool.... plus there is alot of support for uberdata.... what that man is doing is great... i think i will run the blue box at first, then maybe teh hack... (i really dont want to do that cause of the ignition problem) i REALLY want to go with the uberdata as soon as i understand it more. POP... yeah, im in meddy... hit me up when you come down... do you still have my celly # ?
