Driver low beam light not working
LANxCiv
So my driver side low beam lights do not work, high beams do work. I've checked all of the fuses. I also looked around for relevant posts concerning this problem. My connection plug may be the problem since it appears to be all "melty"; just want to confirm if this may be the problem.
lethal6
Your Mom's Moderator
Only you can confirm that. Are you getting power at the plug? Find out where you are losing connection and go from there.
Failsafe88
gt CasaNova
Check bulb first then check for power
LANxCiv
welp the problem was just part of the bulb being burnt out. Immediately switched out both bulbs just in case.
