Also, do your wipers work when you press the switch down and put it on I or II (I don't know the speed names lol)? If they do, your switch may be starting to get bad. Over age, the contacts start to get bad. You can take them out and use a Q-Tip with rubbing alcohol and clean them. If that doesn't work, you may need a new switch (assuming the wiper motor is fine).
