1996 civic hx
ok so my driver window quit working about 4 months ago and i have been ok with it since its winter but now i need it fixed. i replaced the motor about 8 months ago and every now and then my window would work off and on but now just doesnt work at all.
i have checked fuse 10,11 and 24 and there all good. i have checked for battery voltage at the Blu/Blk and Grn/Blk and i get 12 volts, i have checked the motor plug on the driver door for voltage when i press the switch and i am getting 12 volts on the Red/Yel when pressing the switch one way and 12 volts on Red/Blu when pressing the switch the other way an I've got continuity from the grounds in the plug to the door.
i tested the plug going to the motor a couple weeks ago and noticed the 12 volts so i figured the motor had gone bad well i went to autozone this weekend and warrantied my window motor and put the new one back in and it still doesnt work. i have tried supplying 12 volts to the motor but it wont go up or down, idk maybe im doing it wrong but the Fsm says pin #1 - and pin #2 + makes the window go up but it didnt work and i dont know what the other two pins in the driver motor are for
i have also tried the civic master switch input test by connecting Blu/blk to Red/Yel and Red/Blu to Blk and then turn the key on and its supposed to make the motor go down but it doesnt. my passenger window works fine , could a relay maybe make one side work and not the other?
i need help diagnosing this window before i murder something haha. well thanks for any help guys it would be much appreciated
