Dropping my civic fast
tongtyyang
i have a 95 civic sedan and i'm thinking about dropping it fast!
i need to find options of what i need to get to drop my ride.
coilovers?
struts/shock + lowering springs?
else?
R3dline
if u wanna drop it fast, get some air bags ,lol, its just according to what your wanting man, are you just wanting to dump it? or just a small drop?, comfort? or does it even matter, we needa know these things to help you
honda209
CCSC # 8
what he said
im on eibach struts and springs....nice drop, still feels comfortable on mild rough roads. this is conservative though.
want something agressive, full coil overs is the best way to go
exSedan
i have the same question too. i have a 94 ex sedan and i want to drop it so it looks good and rides smooth. can i use the stock struts and just buy some good springs?
1993DX
Chances are if your struts are original, they may not be up to the task of handling the higher spring rates.
If you're just putting lowering springs on it then new oem struts should work fine. Of course if you're looking for a significant increase in handling then upgrading the struts as well is recommended.
If you're you're looking for something smooth, get a matched spring / strut set. They give you some drop, ride pretty good, they're matched so you know the spring rates won't break your back, and they're usually affordable.
Coil overs .. Depends on the kind. Full coil overs give a lot of drop, but can be rough (if you drive on poor roads I REALLY suggest you stay away, UNLESS handling is what you are looking for). The other common problem with coil overs is that people are tempted to drop it too far, too soon. If you drop it too far, your camber will be so negative you'll eat tires like it's cool, it's worse if you have performance tires as they are much softer. The camber should be corrected when dropping significantly, but sooooo many people neglect it and blame their "crappy" tires for not lasting more than 2 months lol.
Coil over kits are -ok- If you put them on a decent set of struts. Nearly all kits take some modification of the strut to get the drop you want, but it isn't too hard.
I've had every freaking imaginable combination you can think of.. My suggestion: A reputable (no ebay crap) coil over kit on adjustable dampening struts. imo =)
TincupVtec
I just bought some 2in drop lowering springs...what would i need to do, or what will happen, if i install it onto my stock suspesion?
xiong87
try my old set up its about 2"drop, neuspeed springs and blue tokico struts! not so low and very nice comfort ride!
xiong87
dont just buy after market springs and drop it with your stock struts! you'll find out the hard way that you'll be spending money on newer struts again! get both aftermarket do it right the first time :D
