ok when you have a dry system is there one silonid (spelling) for just nitrous. there no dealing with fuel.?
Dry systems are fine if you're not spraying to much. If you keep it around a 50-60 shot you'll be fine with the dry system becuase you don't have to worry to much about the flow being more in one cylinder (though it could still happen). If you're running over a 65 shot though definately run wet, because that is where you start running into problems with the flow to all of the cylinders and having some run too rich and some too lean.24-7 said:Dry systems are not a good idea.
4doorcivic16 said:there two nos fuel solonoids my friend gave em to me they were on his dragster.
good luck with that.. not worth it.. by the time you buy all the fittings and such it will cost a lot..4doorcivic16 said:home made
