EF Honda EF
hey i have a homemade turbo set up. i intalled everything and ran it a little with stock injectors at about 4-5psi. but we wanted more so we installed the dsm 450cc injectors. i know that they are alot more than stock. well when i hit the throttle a little it dies and then revs up sometimes just dies. it ideals smooth after it worms up but still it dies when you give it throttle. if you hold the gas at a steady rpm(about 3000)it sounds like it is running real bad and missing a lot. please help. do i need a tune and what could i do to compromise just to get it running right. should i get different spark plugs that can handle the fuel?
