DX Revive
DomkeBoy
I put a lot of work into this car and got real lucky with some deals. Bought it with...No engine. No transmission. No grill. No fender plastics. No bulbs. Rusty steelies that shake with winter tires. A disassembled & partly missing interior. A wiring harness that was covered in dirt & oil, also had a couple broken clips & was half un-covered. All kinds of pizza boxs, empty cigarette packs, & socks. Tones of other garbage. The passengers front engine mount had 2/3 stripped nuts, had to drill into the body and replace them. A cut half shaft. Axels hanging. Had to cut the axel nuts to get them off. It had some blown out EF struts w/cut springs (just for cross town towing purposes). It had a ridiculous cheap fart can with a 4" slant tip along with a discussing sheet metal rivoted on carbon gaurd. It did come with skunk2 upper control arms though, but the ball joints were bad!
I wanted a project and the shell was fairly cheap and reasonable.
So I bought it & got the title. Then towed it across town. Got a bunch of d16y8 parts and over part of the winter busted out a facory rebuild. I gathered a lot of other oem parts. Eventually put the thing back together. It runs great, vtec does not work though?
The knuckles/brakes/hubs are all from a DA Integra. The exhaust is 2" all the way. Cheapo 4.2.1 headers with a custom flex pipe and flat flange welded on. Where the cat usually goes I got a 2" honda resonator. No more flanges straight to the muffler, which is off of a Subaru 2.5 RS. All hung and mounted very nicely. Sounds amazing. Breathes like champ. I think the intake is a z6 manifold.
Here it is...
I finally got to clean it at home to get all the greasy hand prints off HAHA. Lucky the snow is finally melting.
Night shot
More...
Valves & Springs - Pistons & Crank = 60k miles
Fixed up the wiring harness
I HATE WINTER!!!
Im pretty happy with it for a daily driver. I love driving it. Gas milage is much better than my last car. Its got a good sound system in it too. Del sol wheels are are waiting for it. There is definitely a few things to be finished. Once the weather is nice I will repaint it. Thanks for checking it out.
mportedcivicsi
Looks pretty good. Nice work getting it back together. Not a fan of the headlights but if you like them thats all that matters =)
DomkeBoy
Thanks. I actually do not like them. Eventually I'll try to find some OEM Valeo headlights later on. I just cant really afford extra stuff and these were free so whatever. HA.
evilrilla2
looks like its going to be a ton of work!!! Its already alot of work fixing up civis that are decent running, you are like 100 steps waaaay behind. but good luck!
Robin...
D-Series Soldier
Needs work man but you can do it, good luck...:thumbs up
emerican
Defintly needs work but it can defintly be done and turned back into a really nice ride. Tuned in for more progress on it.
DomkeBoy
Thanks guys. I actually got the del sol wheels on it. It looks much better. Its snowed in, but I did get some OEM headlights yesterday for when I dig it out. Today I am fitting in the cup holders to block off the rest of my lower head unit mounting.
Also I think I am going to get rid of that spoiler & get the SI style. The one on it is from an EG I discovered.
I found another shell locally. It is a 99' and I am picking it up soon for cheap. So I will have completely new doors that are rust free. Plus dark grey interior with freshy matching back & front seats. Trunk guts, a spare trunk along with some spare parts I can sell. Im getting really anxious about painting this thing. I may pick up some tein lowering springs from a young local. I'd still have a little wheel gap, but Im kinda going for the stock look anyways.
Check out the wheels and new snow drift spoiler! HAHA!
DomkeBoy
Wow its almost been a year since I updated this. Lots has happened. I never did put up a picture of the block though. Thought I did, guess that was a different forum? Here is one for good measure though :]
Since I have last posted on this thread I have lowered the car, switched the doors/trunk/hood, switched headlights, replaced tie rod ends/ball joints/rear calipers/rear rotors, relocated battery, purchased fog lights/hood bra/roof rack/center caps, acquired new front bumper/mudguards/front & rear upper strut tower bar/integra rear sway bar. Plan on getting extended lugs & extended steel nuts. SIR style front lip. Window Visors & tint. Coilover sleeves. Possible Hasport GOLD mounts. Paint. Done DD project.
Here are some pictures to hold you off until I get a chance to take more & finish up a couple things :]
I bought another shell, but the front end is smashed. It is a 99 hx, using the entire interior out of it. Swapping that soon while I do my wire tuck. Car is parked for winter. Spent all my paint money on my Subaru :]
THEDARKONE
your my hero :guns:
i see that you have the radio bye the cup holders
im guesing you need a radio block off plate here's the OEM part #
77230-SM4-G00
DomkeBoy
your my hero :guns:
77230-SM4-G00
Thanks, is that for the 96-98 or 99-00? I got both HA! The only ones I have found were for 99-00
SoJ1Ro
just sit back and enjoy
Good Job, i see everything is coming along nicely
DomkeBoy
Thanks guys...hopefully it's not too long before another update. Should have pictures of wire tuck & interior change.
DarkCreep
D16Y8+T
Ive always wanted to do something like this.
POST MORE PICS PLEASE! Lots of them!
DomkeBoy
Haven't been posting, but I sure have been collecting. I recently went from my akimoto 3" intake tube to a 2.5" I rigged up. Put my old filter on the subi & got a new Blox filter & velocity stack...it totally fixed my velocity issue & runs much better! Plus I decided I wanna turbo it. Parts & pictures!!!
Things collected for turbo so far:
JDM 62mm Throttle Body
IHI VF Turbo (ball bearing internal waste gate)
Intercooler & piping w/ cupplers
B.O.V. from mrk4 wolfsburg jetta
Oil cooler
Blox FMU
Blow MAP Adapter
Boost & Oil PSI gauge & cluster trim w/side pods
Heat Wrap
Misc. fittings & hoses
Just need:
Custom Exhaust Manifold & downpipe
Misc hoses
Now for some pictures...
I have had the turbo, throttle body, & cluster trim laying around for a while. Pretty sure I just got the rest of what I needed though. Had a lot of time to think while it was parked all winter. Winter is OVER! Plus II know a guy the used to be a fabricator for LoveFab & he is local. He might hook me up with a cheap or free header just for rep N his garage. Well see. MORE TO COME FOR SURE.
