This is a thread I made over on EJ8squad regarding sound deadening. Do this, forget Dynamat.
This is intended to be a living document explaining auto sound deadening for your EJ8. This information is compiled from multiple sources. The goal here is sound deaden your car for under $100 bucks and not add significant weight with the products suggested below, you can do this. Please feel free to tac on your own experiences and tricks of the trade.
Commercial auto sound deadening products, such as Dynomat, BQuiet, eDead, Fatmat, Rblocks are all essentially reproductions of housing construction grade sound deadening - aluminum foil over a butyl rubber base. There is essentially no functional difference between these products and "roof barriers" such as Peel and Seal and
Quick Roof.
Roof barriers are approx 40-mil thick but Quick Roof also offers a 60-mil material called Stormblock.
http://www.cofair.com/sb60.aspx. All these products have adhesive backing, which is perfect for applying to the inside of your stripped-down vehicle.
I read about how some car audio shops "stumbled" onto this solution in the '90s - it does the exact same thing as Dynamat but for about 20 percent of the cost. Honestly I think Dynamat started by repackaging similar stuff.
The 40-mil stuff is all about a buck a foot and it works really well. Double up on the firewall, the area around the rear window and rear parcel floor and the car will get real quiet inside.
Home Depot carries Quick Roof.
Lowe's carries a similar product called Peel and Seal.
Both are roofing products with adhesive backs, but apparently Quick Roof is a tad bit more effective.
I've heard, although not seen for myself, that you can do your whole car for around 65 bucks. http://www.yourautotrim.com/ has some good prices, but I'm sure there are more sources. If you were to use Dynamat, the same sound deadening would cost between $300 and $400, without any significant difference in effectiveness.
Some pictures of Civics with Peel and Seal..
Also, see
this link for inside the door
It's also common to double up Peel and Seal/Quick Roof with a product called Thermozite, also known as Jute. I've found 27oz of Jute online for seven bucks. Termozite is a bit more expensive, but looks a bit thicker. This product helps diffuse sound, and has an aluminum backing to keep out diffused heat. It's common to put it ontop of the Peel and Seal/Quick Roof with latex caulking.
Notice above how it's placed ontop of the wheel well to reduce road noise
Also, ever notice how once you put a sub in your truck it takes up a butt-load more space, and depending on its size, can get in the way of getting to your spare? Here's a quick DIY schematic for making your own trunk floor that'll be more functional once you have a sub installed!
Basically all you have to do is trace the outline of your stock trunk floor onto 1/2" MDF, or something else of your choice. Then cut a rectangular access door for the wheel, and add hinges, as seen below:
Here is a picture of the access door open
Again, please feel free to throw your own information in this thread.
