I'm just curious, has anyone on here dynamated their interior? good effect? bad effect? big reduction of road noise? does it make the car sound...."more solid" thats just what i've heard some1 say
yes yes yes. No bad effect other then adding a little more weight. Take a piece of dynomat on a bell and try to ring it, the sound will be dead. Good stuff. Car wont sound like a panel shaker on the outside.HondaSpeedaX said:I'm just curious, has anyone on here dynamated their interior? good effect? bad effect? big reduction of road noise? does it make the car sound...."more solid" thats just what i've heard some1 say
I don't know how hot your car would get, but haven't experienced any problems yet.Beelzebubba said:The only thing I'm concerned with about that adhesive roofing stuff is that it will smell of tar when the car gets hot.
I just used regular Dynamat. I really don't see how the layer of aluminum foil makes Dynamat Xtreme any easier to use
how much it cost to do the whole car?, what's the name?Civicboy10 said:My brother used that adhesive layer that you put on roofs before the shingles (don't know what exactly its called)...its basically the same material as dynamat...cheaper & you can pick it up at your local hardware store...its not what I would recommend if you are looking for the best quality, but it does make a pretty good difference, or at least WE noticed a significant difference.
I'm not too sure...we just used some that we had lying around from when we did our house, but I'll look into it and post up.Jas0n said:how much it cost to do the whole car?, what's the name?
