First, we'll have to take his claims through the "bullshit" filter so you know what you're gonna get. If you said you saw, with your own eyes, the shop dyno a 250 hp B16A2, then I guess you know they have one for sure. But let's consider some other factors besides, the numbers okay. 250 hp @ the wheels is a monumental task for a naturally aspirated 1.6L, VTEC or not. To achieve that, it'll take crazy compression and huge cams. Something seems a little fishy and $2800 dollars seems a little "cheap" for a fully built, blueprinted, multivalve-ported monster. And already, I know the guy took some "shortcuts" in the build-up. But first, let's talk compresion...let's face it. It's gonna take sky-hi a compression to achieve 250 n/a rwhp (that's over 270 hp at the crank!). Much more than 11:1 or even 11.5:1. As a rule, running on aluminum heads, you won't be able to get much higher a compression than 12:0 on 91 octane piss. Even then, it'll take an air/fuel ratio that's gonna flood the cylinders, atleast and air/fuel ratio of 11:1 (read:RICH!) to prevent detonation. To put it another way...you'r NOT gonna make 250 rwhp on 91 octane without a lot of magical cooling additions to prevent the engine from going boom. The tuner is probably trying to sell you a pooly "assembled" engine and use a C16 eating monster to attract buyers. Or maybe he isn't lying...to a certain extent. You see here's another lie I caught from your engine builder. YOU DO NOT HOT TANK ALUMINUM BLOCKS!!!!!!!! Oh, I just thought of a fun little experiment for you. Go and tell the guy to hot-tank that little b16 and let you watch him do it. Hehehe...the caustic solution with dissolve that little engine like Alka-Seltzer in hot water. We know never to hot tank a Chevy Aluminum block, but seems like your friendly engine builder here is quite unfamilar with engine building (Yes, B-series are aluminum). And unless somebody disconvered some magical way of hot-tanking aluminum blocks...DON'T DO IT JOE!!!
