So, for some strange reason, im not sure if this is an electrical problem, or a brake problem but here it goes. Apparently when im driving normally, with the e-brake down, my e-brake light turns on, then turns off. I've been trying to figure out a pattern for it, but its hard to tell, as it is very inconsistent. A few times it will turn on when i hit around 2500 rpms in first gear, and wont turn off until i shift it into third, shifting at 3000 at each gear. It doesnt do it all the time, and if anything in only stays on for a few seconds, at most. Does any one know what could be causing this. When i set my hand brake to park it works normally, i'm just not sure why it turns on and off like this. Only mods to the cluster was a ex cluster swap for the tach, and a ctr cf bezel, except both were done two years ago, and i havent ran into this problem until now. Any help anyone?
