ecm out of the way on gsr swap
Anti-Ricer
I have a gsr swapped 92 hatch and would like to know where yall mounted your ecu? Mine is laying in the floor because it wont fit in the stock location.id like some pics of where and how you bolted your ecu up
AlaskaB16
DOING WORK!
Are you running a chipped OBD1 ECU? That should not only fit in the OEM ECU location, it should just about fall right in place AND give you an HJ on the way in just to thank you for being so awesome. Are you sure you're doing it right? I mean... It only goes in one direction (And i'm not talking about the boy band..... or am i?)
Anti-Ricer
I dont know nothing about the ecu.it says awl on it and the rest of the letters are faded off.its a BIG ecu tho I dont see how it would fit.
AlaskaB16
DOING WORK!
That should fit no problem. When mounted, the wire harness is on the bottom of the ECU. Google "EG ecu location" or something similar, click on images, and then scroll through to find a good picture of how they're mounted. Should fit like a glove.
