ECU for nitrous
Trays95Vtec
LOW (but slow)
hey everyone , after building my motor , i want to move on to an ECU , but which ECU would be safe for use with a wet nitrous system? any help would be appreciated
banzai
Exit Speed Garage
what engine?
io_303
NIFOC
depending on the ecu and engine, you can eather buy a chip off ebay, or go with a reprogram. www.pgmfi.org is a good place to start looking. Also try hondata. one final alternative would be an AVC or MSD box
EDIT: uberdata is the free ecu chipping program. just go to PGMFI and read the wiki...please no posts of.."show me how to chip my ECU" search is your friend
Shiznit
Stickin it to the Man
well if you have a stick (which i hope you do) then your current ECU is a perfect candidate for chipping and running uberdata
io_303
NIFOC
forgot that part...yes chipping programs only work with a 5speed
Trays95Vtec
LOW (but slow)
i have a D16Z6 , yeah its a 5 speed , (my car is a 95 EX coupe) right now i feel i need a lil more fuel to it but im scared an ECU would jump the timing and cause detenation, as far as the mods i have pistons rods , comp nitrous cam ,pulleys, header , skunk2 intake mani , edelbrock TB, so would the ECU be the way to go , or would upgrading my injectors, fuel press reg and fuel rail net better results?
Shiznit
no, youll get the best results if you upgrade your injectors and chip your ecu. all you would have to do is tune it. its the BEST way to do it
io_303
NIFOC
since its a wet kit, you wont need the bigger injectros....its more in the timing for you....you need to retard the timing just a bit when your on the bottle
