compressions fine in every cylinder, plugs spark and all that.
cylinder 3 wasnt receiving fuel so i was thinking fuel injector but before i went out and spent basically $100 i wanted to make sure it was the fuel injector. So i swapped my injectors for 3 and 4 and sure enough, 3 still was dry and idle didnt change when pulled.
The only other thing i can think of is the fuel rail, or the computer. im leaning more towards the computer due the the circumstances, just looking for more experienced opinions please.
its a 96 ej8 coupe with a 99 b16a2 swap from an SI, (95% of whats under the hood is from the SI ), the computer is a p28
ANY suggestions or comments are much appreciated, i really wanna get my baby back on the road
edit - oh CEL is on for crankshaft position sensor but i had a space distributor and tried every combo with the distr.'s and sensors - can re aligning the crank shaft (if needed) potentional fix the problem?
