I am looking into buying a chipped p28 ecu from j-k-tuning.com and it asked what socket type I want, either a DIP or ZIF. What is the difference?
dead meaning people dont reply to threads anymore and not alot of users are on here anymore. Most OG members have left. Get the p28 chipped but used the zip socket.clover ej6 said:well i need an ecu too because i have the y7 ecu and am converting to a y8 and i think it would be easier to just get the crome chip from j-k-tuning.com. What do you mean about cc being dead?
I made the car but not the actual avatar...there is thread on here that has them they are member created. Check the photography section.clover ej6 said:Yeah, I've noticed more OG members have left since i joined originally in December of 2005. Did you make your avy?
that would be a OLD thread.defvayne said:I made the car but not the actual avatar...there is thread on here that has them they are member created. Check the photography section.
what do you mean any "P"Inigo Montoya said:zif = zero insertion force. highly recommend zif'n your girlfriend... less abuse on the moving parts.
anyhow, zif is where its at.. like $7 more and youll never worry about breaking a chip again (there a b***h to pull out with zip sockets)
p28's are all the same as p06/p07/p08/p30/p72 with just a couple more frills and resistors for knock sensor and vtec. Any "p" ecu can be modded for the obd1 application. p72s come "chipped" stock.
oops shouldve said p##. so voiding out p2p/p2e etc (thanks for the heads up, edited to avoid confusion)Green 91 said:what do you mean any "P"
what abotu other OBD series P ecus
Pm6 ect.
yep, i have a JDM OBD1 P29 ECU.Inigo Montoya said:oops shouldve said p##. so voiding out p2p/p2e etc (thanks for the heads up, edited to avoid confusion)
Jspec ecu's are also smaller in size which can make them a little trickier to work on (mainly because of their layout)
seems like it.Green 91 said:that would be a OLD thread.
i think your the only one left with it.
Inigo Montoya said:p72s come "chipped" stock.
Yeah just get that one with the zif socket.clover ej6 said:So is this a good ecu to get, with the zif socket? http://www.j-k-tuning.com/chipped-spec-p-292.html
