ecu replacement question
99civicchic
i bought a used ecu off amazon andim gonna plug it in myself cause im tired of waiting for someone to do it. i have read that its a plug and play part so do i need to reprogram it at all? im thinking not but i might be wrong so any help would help:roll::roll:
chromal
Really depends on what you have and what you bought. For example, the ECUs are set up differently for automatic vs manual transmissions, or vtec vs non-vtec. And this isn't even getting into OBD0/1/2a/2b differences...
chromal
If it's the same part, then it should be pretty much plug and play.
civexspeedy
So long as it's a matching ECU, you just plug and play. Just make sure you disconnect the battery before your remove the old ECU.
mymmeryloss
RHD is where its at
:popcorn:
Sent from my Butthole using Fart power!
