EF Honda civic
justhonda
ok i have a 1989 EF Honda Civic.
what i need info about is, The possibillities off dropping any kind of vtec motor into this baby with out any engineering of sorts. is this possible or will the engine mounts need moving to fit all vtec motors. or if u know your stuff what kind of head i could swap for the stock engine block.
i thank all who help me out with my project cheers =)
James315
your pretty much going to have to convert to obd1 or 2 depending on what you want to do and make some changes to your wiring harness unless you find a obd0 b16a from an ef9 still harness changes but no need for obd changes.
Mr.Baker
Mr. Search
sorry im not famillier with the term obd1. what is this obd1 .
thank you for helping
With that said, you definitely need to take some initiative to read and research.
Here's a little bit of help.
OBD - On Board Diagnostics, built into Engine Control Units (ECU).
3 Levels, OBD0, OBD1, OBD2.
ECU monitors and has ability to retrieve engine trouble/codes.(When your CEL or Check engine light comes on.
There is lots of info out there if you're willing to take the time and look, especially when dealing with a 20+ yrd old platform.
justhonda
ok i understand the term now i did before but in my circuls its just called a wiring harness but now i have more understanding of it thank you.
JohnS.
BANGARANG
:welcome:
Looks like you've got a lot of reading to do. Google is your best friend at this point.
Most Honda motors can be swapped into other Honda's with ease. There are companies that have specially engineered engine mounts to essentially make everything a bolt-in process at this point. OBDI is more tuner friendly since there are less emission restrictions. You have a pre-96 (96 and up is OBDII) car anyways so you'll be fine.
justhonda
ok kwl thanks heeps im reseaching on my new friend google for info thanks everyone for your help cheers
