Yes. 10A dash fuse 19.My dash and taillights went out. Is the dash the same as the taillight fuse?
Can you get a test light or multimeter?I changed it but it still won't turn on.
Disconnect your tach wire and bring the wiring back to stock. Then replace fuse 19 to see if your lights now work.Actually.....it might be the wiring??? I'll check. And my friend is bring me a tester what settings do I use
These are extremely inexpensive but powerful tools that you need to solve this problem. For example, you can often buy an adequate digital multimeter for $3 from Harbor Freight Tools. You can buy a test light for less.
