clean95hatch
Vehicle in question: 1995 Civic hatch DX 1.5l
Problem: won't start
So a friend of mine decided it would be a good idea to play a prank on me. He unplugged one of my spark plug wires *at the distributor*. I didn't know he did this, and I went to start the car. As I'm about to leave, he walks over and says "oh yeah, you should plug that spark plug wire back in, I thought it would make a more obvious difference in the engine." I go under the hood and see the wire hanging about 1/8inch from the contact point on the distributor. I can see the spark arcing from the distributor to the plug wire. ...then the car shuts off on its own. It won't start again. I've checked all the fuses, disconnected the battery to try to reset the ECU, taken off the distributor rotor to check it out, etc.
I have no idea what to try next. A friend of mine suggested that the ignition control module inside the distributor might have been fried by the spark re-arcing backwards into the distributor or something like that.
Any ideas?
Any ideas?
