Which is more important to get it you had to pick between the two. I want the least ammount of gauges i need. Preferably two but just help me out on this one
That's a negative. The EGT tells you how close you are running to lambda since peak temperatures occur at that air/fuel ratio--richer or leaner the temperature drops off (provided all other factors are unchanged). The trick to tuning with the EGT is to know what side of stoichiometric you are on (rich or lean). An A/F gauge can hint you if you're running lean or rich, but really it's only good for a light show and at WOT. I do not recommend testing a boosted car at WOT to see if you're rich or lean. If you were to get only one gauge, get EGT.SeanMc300 said:oh god, didnt we already answer this!!! the egt gauge is a more accurate way of telling if you are lean or rich. its alot better.
Yep yep. And the impeller shaft will be spinning at tens of thousands (sometimes 100's) of RPM's, cutting off oil flow to the shaft and bearings would lead to short turbo life. Don't recommend it without proper continuing oil circulation after a hard pull on a turbo vehicle.TurboZinc said:Freeflyin also makes a great point. Checking your plugs can give you a great idea of what the engine is doing. The only problem, especially on a turbo car, is shutting the car down immediately after a hard pull. The oil is still extremely hot, and will coke up on the bearings and shaft.
