Ek tailights not working
Ek_Coupe`
Having a problem tailights are not coming on passenger trunk right light in one of the sockets it started to burn out so I removed the bulb and that harness in that casing ever since I pulled the fried bulb my tailights stopped working also my corner lights in the front work when turning they blink but wont stay on... rear left and right now blinkers are fine I want to get this fixed asap hate not being able to drive at night and not able to go to car meets at night ( not trying to get a ticket)
HeX
Authoritah, respected.
Please edit that post as it is unclear. Use punctuations and write clearly so you increase your chances of resolving this.
Check the fuses under the dash then replace that bulb.
Ek_Coupe`
:thumbup:
Dash fuse #32 is almost certainly blown.
Yes fuse 32 was the problem, now I need to find a short because my right corner light only works when hazards are on and my driver side rear corner light isn't working parking light next to it works parking light on passenger side doesn't work but the passenger corner works how would I resolve this? Also hazards work on both corners in the rear.
Ek_Coupe`
Do you have a coupe? What year?
Front
There are two front bulbs, one on the left side and one on the right side. Each bulb is actually two bulbs built into one, with one filament used for the turn signal/hazard light and the other filament for the parking light.
Rear
There are four rear bulbs, two inner bulbs (right and left) and two outer bulbs (right and left). Each bulb is actually two bulbs built into one, with one filament used for the brake light and the other filament for the taillight.
Clearly state which specific parking lights and which specific taillights do not work.
Yes i have a coupe a 1999 ek coupe ex, and the lights in the rear that don't work are the left rear outer and the right rear inner.
