Hey everybody, I have a 99 Si that is not a daily, i got in it the other day for the first time in a couple weeks flipped the key and the battery was a touch low (lights were very dim) so i did not even try to crank it over, I grabbed my daily, went to jump it and when i put the key back in no lights worked, nothing worked, i let it charge for a sec, tried it again and the horn started blaring but no lights, nothing else. I quickly unclipped the horn as it was really annoying.
I have checked the main fuse box, fuses check out, i checked the grounds they look alright, i charged the battery and still get nothing. I do have an alarm system on the car but it was off, is there any chance it could be wired to trip and shut down the car if it (the car) receives a large gain in voltage, and if so should i try to unplug the ecu to reset maybe whatever happened? any suggestions before i start thinking about calling someone else or spending money. Thanks
