So, I had my CTR power folding mirrors fully functional and working using the switch with the single row green connector. I then picked up a dark gray switch to match my dash, however when I installed it (followed the pin outs over correspondingly), now the mirrors don't work. I tried to use a wiring diagram that dictated my plug, however the switch is different as it has a dark gray plug and it seems as though it's almost an integrated relay on the back? Possibly a way to bypass the other OEM relay.
**EDIT: Also, on the new switch, the button stays in when pushed in as opposed to the first switch in which it would retract back out once pressed. This URL here: http://www.jdmpro.com/picture/foldingmirrors.htm, shows that with the radio shack relay, the button has to be held all the way in, the whole time. Thus, it makes me think that the piece on the back of the switch is an integrated relay. But how to wire it?
I just need some help because I've tried every method to wire up the mirrors, but can't get them. So I'm hoping someone has used this switch before? Here's some pics:
Thanks!
PS> if you have no idea what the f**k I just said, tell me...
Thanks!
