xplicitcivic94
when i connect my battery, the fuel pump primes and gauges come on as if the key was in.
i check all fuses, unplugged the ignition switch harness(both) from under steering column. i unplugged all 3 shock tower plugs. funny thing is, when all 3 are unplugged, the gauge cluster(brake and check engine) lights are still on. when i plug in the 2nd largest, the fuel pump primes. what else should i check?
any help would be greatly appreciated. thanks
