It might sit at a funny angle if you put it on the pillar. I think it's meant to be mounted on a flat surface. As far as connections and mounting go, the connection should be the same, but who knows with the mounting. Check the schematics on HondaAutomotiveparts.com. Still, it would be inetersting to see. I've been looking for a nice roof mount stubby antenna myselfSRLNCLT said:Is this possible? I was looking at the antenna base and its a little wider but if the wiring is the same could this work?
thanks
L.
wake_rider said:^^^ why not drill? rust is great. Drops the weight of your car, and as all ricers know, that makes it faster.
