EM1 Build **Blue Beater**
MyEmWon
Hey guys looking for some feedback on the build I have in process. The motor is a traditional B16A2 with the Si trans and we are hoping for between 600-650hp on E85 at the wheels. Here goes the list, (*) indicates not yet purchased. HPT Autosport of NC is currently doing the head work and final assembly of head and block. Golden Eagle of NC currently has my block and is doing internal assembly as well as sleeving. I know I am forgetting to list other items, these are just off the cuff for now. Some head items may be replaced depending on how much more effort will be needed from the head to reach the goal (it started as a mild N/A rebuild). Evans Tuning will be doing the dyno tune once the car is totally finished around fall 2017/ summer 2018. I am working on a Doctorate in PT so money is slow as I am in school, I have been acquiring parts for the past year.
Block
Wiseco 81.5mm/10.5 c.r. pistons
Wiseco upgraded wrist pins
Manley Sport Compact Connecting Rods
Stock Crank
Golden Eagle Sleeves
Golden Eagle Assembly & Blueprinting
*Dampener (not purchased yet needing PS no A/C)
All ARP Bolts
Head
AEM Cam Gears
AEM Fuel Pressure Regulator
Skunk2 Stage 2 Tuner Cams
Skunk2 LMA's
Skunk2 Alpha Springs & Ti Retainers (may be swapped out)
HPT Head Assembly and Porting (if we need it)
Skunk2 Ultra Street Intake Manifold
Skunk2 70mm Black Series Throttle Body
*Supertech Valves (may be oversized if porting is needed)
Hondata Coil on Plug Conversion
All ARP Bolts
Fuel
ID2000's Fuel Injectors
Walbro E85 450LPH Fuel Pump/ hot wire kit
AEM Fuel Rail
Electronics
Hondata S300
Turbo/Acessories
*PTE Billet 6262
*PTE 39mm Wastegates
*PTE 64mm BOV
*Full Race Single Back Door Intercooler
*Full Race Twin Scroll Top Mount Exhaust Manifold
*Boost Controller
Transmission (Si)/ Drivetrain
MFactory LSD
Synchrotech Carbon Master Rebuild Kit
Competition Clutch Twin Disc
*Drive Shaft Shop Level 3.9 Axles
