fuel not being added at all.
Please read every bit and consider any problem, i appreciate your help.
ok, so i did the emanage install, set the rotary to 4-8-c, then the jumpers to whats recommended in the emanage install DIY on here.
the injectors are rsx-s, i did the injector size change on emanage and it works, car runs fine.
the tuner starts tuning the car today, and he says he starts adding fuel but nothing happens, he put it to 100% duty cycle on almost the whole map and no change really at all. wether under boost or not. any suggestions of what to check? or what may be the problem?
also when he adjusted the ignition, just 1 degree advanced at idle the car started running rough and went from steady 850 to a searching idle from about 600-1300. so he took back that degree and it was fine again. any ideas?
im open to any and all suggestions of what to do, what to look at.
do i have to turn those yellow things on the side? i thought that was just for if you arent tuning it with software.
ive got rsx-s injectors as only fuel upgrade. and as for engine mods, long list short, ive got stage 2 turbo cam and t25 tsi kit.
this is a 2002 civic lx (ex head swap)
