I installed the emanage without hooking up the RPM wire and it seemed to run fine with the green light staying on the emanage. When I hooked up the RPM wire the green light went out and flashed red repeatedly. Can I run the emanage without hooking up the RPM wire. Also there are three wires running from the MAP, a white wire labeled PB, a green and blue, or green and white labeled SG1 and a yellow and green or yellow and red labeled VCC1. I hooked the white wire to the emanage, is that the correct wire? I have searched turbod16 and the only good thread wasn't working for me.
