engine bay power source
hatch2000
Where can I find a good power source in the engine bay for an in-line fuel pump? It's mounted on the firewall almost next to the fuel filter. For some reason, the other day, the source that it was connected to failed. the positive (from pump) was connected to a black w/ blue stripe wire I believe. So then I tried to connect the positive directly to the battery to see if the fuel pump died but it worked, also everything else that was connected with it (radiator fan is that only obvious one I noticed). So I'm guessing that the source that the black/blue wire was connected to is loose or bad, but I can't follow it because it's covered and goes underneath the manifold somewhere.
So final question is, where can I find a positive wire that can handle the pump and fan or more when I turn the ignitioin on?
**edit: I have a 94 b18c
