newdaynewek
Hey everyone,
I haven't been driving my car much at all, but recently i've taken it out a couple times. My car has 126,000 miles on the engine, its a 1998 civic ex. whenever I drive it sounds like somethings dragging, but nothing is when I looked under the car. It sounds like a deep toned dragging that gets louder as I go faster, the sound comes from the rear right corner of the car (near the exhaust tip) best way I can describe it is if my tire was rubbing against something. Also when I turn off the car after my drive, steam comes out of the exhaust and a burning smell is present. Another thought is that maybe something is clogged in the exhaust or there is a constriction of airflow somewhere within the exhaust?
Also whenever I start the car, it sounds like the engine is literally about to die. It putters and idles really low (below 1 rpm) then eventually goes back up after a couple seconds. But it sounds scary when it putters, like any moment it could die. I checked the engine oil, coolant, everything seems fine. Maybe the air filter could be the cause? I haven't changed that in a while. It is so weird because I literally haven't driven my civic in a while. like once every couple weeks and only locally, never long distance. So I really don't know how this issue came about?
Thank you CC!
Thank you CC!
