engine starts to smoke as soon as it starts
rubyleigh09
Hey hey everyone, I've been working on my civic again. It just recently started smoking out of the back of the engine block and around the turbo area. . . I know I have a exhaust leak but this is pure white smoke. It started after I changed the spark plugs, I mean it's always smoked a little but now it's really smoking. . . Like a lot, is there any way that it could have a blown or loose head gasket? I don't see any oil leaking on the back of the block where the oil feed line is? I'm not really sure what's going on. Maybe it does have a blown head gasket I don't know. PLEASE HELP
rubyleigh09
by the way the engine is a turbo charged d16 vtec engine....
Awesomesauce
my old d series did tha one time when i didnt have raidiator fluid in it also no oil can be the same. A blown head gasket would smoke out your exhaust
rubyleigh09
Checked coolant and it's good, checked oil and it's good.
Avant Uprising
GONE FISHIN
i guarantee its a headgasket. drain the oil there will you find your answer. boost on a stock internal d series they dont last to long if your rough with it
rubyleigh09
It doesn't have stock internals... so I don't know what your talking about with that. It's got a built bottom end. . .
It's got arp head studs and everything else
And I havn't been rough on it at all.
RealRabbit
What head gasket were you running? Also arp head studs are amazing, but you have to use the arp lube which isn't provided. Also follow the torque procedure to the T.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
