My '94 Civic starts and runs great every time except when it rains. It gets a good spark, I replaced the fuel relay under the dash and the fuel pump seems fine. Has anyone ever heard of a situation like this?
Do you drive it around in the rain, shut it off than find out it won't start? I would check around the shock tower passenger side connectors. Only cause its close to the wheel, where water can potentially splash up in there. More details would help.
If and when it starts on a rainy day it runs fine until having to restart even after a brief stop. I will check the distributer for moisture and probably replace the cap and rotor. The plug wires look good but will keep them in mind as well as check for codes. It's supposed to rain here later in the week so will know more then. Thanks for the suggestions!
