Engine wont start
pitoutios
96 honda wont start. Engine turns over but wont start. About 6 months ago the starter would not turn over with the key. Iwired direct to the starter and it would crank with a push button. The car set up for about a week. it started fine I backed up it died and would not start again. never had a problem before.
~XhAuSt~
Sounds like a Fuel supply issue. Check : Fuel pump fuse, fuel filter, another thing you can try is turn the key to the on position and see if you can here the fuel pump working at all, if not that could have packed it in. Let me know what you find helps you out.
mymmeryloss
RHD is where its at
Check for spark.
Pull a spark plug and crank
