Evap leak at gas tank - can I use plastidip?
myfavecoupe
[/URL][/IMG]Car threw an evap leak code. Had it put on a smoke tester and smoke was found escaping around the fuel pump and fuel sending unit covers.
They look pretty rusty especially sending unit cover so I'm iffy about replacing the gaskets and breaking a stud/nut or just having the metal fall apart.
Could I simply use some kind of sealant that's not permanent around the lips? Was thinking using some plastidip
motakitty
I wouldn't just cause the chemicals and fuel vapors might not like each other. You need to fix it properly
Sent from my VS930 4G using Tapatalk
lethal6
Your Mom's Moderator
Plastidip is a paint not a sealant. It wasn't designed as such and won't work. Do it right the first time. Just use a good rust breaker (ie: pb blaster) and let it sit, then take the bolts out.
cgpEJ6
noob
Fix what's broken, don't just cover it up.
And no, Plastidip wouldn't work.
HeX
Authoritah, respected.
I agree with them. Fuel containment and delivery is not something worth rigging. I wont even suggest a sealant because its just dangerous. Attempt to properly fix the issue before you blow up yourself or hurt others.
Wreckless Hype
¯\_(ツ)_/¯
And it sucks at that.
When I need something to sit for a good bit, I usually use Mopar Rust Penetrant. I use PB for absolutely everything, but this Mopar spray is pretty awesome; it sits and foams up where you spray it, no drips or anything. Get it online or any Chrysler dealership, think it's like $10 a can or something.
myfavecoupe
Thanks. That fuel sending unit cover looks like it's about to break into little pieces if touched but I'll do it properly.
Anyone know if those gaskets are dealer parts only?
HeX
I believe it is a dealer special-order part being that its a gasket that hardly gets replaced.
